1jzgte headgasket
I bought a 1jz with 34k miles. I looked at the oil and it was chocolate. The place where I bought it from told me that headgaskets never usually go bad. I've changed out the cam seal and front + rear main seal. Should I change the headgasket now since the oil is bad? This is my first swap so im not too experienced with all this.
Thanks,
Andrew
Thanks,
Andrew
wait is this engine in the car, or are you in the process of swapping it??
if it's in the car and running, do an oil change on it and see if the problem returns after some driving. Also check the coolant to see if it's disappearing or changing to a similar color as your oil.
oh sorry for not saying. The engine is out of the car. I am in the process of swapping it in but I may just go ahead and change the headgasket to be sure. Which is more money that i'll have to put down. Better safe than sorry I guess.
Thanks,
Andrew
Thanks,
Andrew
