Who has the upgraded alternator?
Old 03-09-11, 03:30 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
When you have bass ratttling boom, you need to upgrade the alternator to keep the headlights from going dim, every time it hit a bass note. It will even cause the interior lights, radio etc from dimming.. Very bad on electronics
Old 03-09-11, 05:35 PM
1WILLY1
1WILLY1's Avatar
Originally Posted by HEWJsc4
If you plan on running a high watt sound system it is a good idea.
Originally Posted by QwkSC
Way to resurrect a dead thread lol.
Higher amp alternator just help's keep up with the electricity demand your sound system is making.
Update, I went with a 145Amp alternator for my year model from EBay.
cool thanks for explaining that guys
Old 12-19-11, 12:10 AM
NaturalJZ
NaturalJZ's Avatar
So my 94 sc300 alternator went out. (170k miles) Upgrade is in my interest.
Few questions:
Stock output is 80 amps?
Are there any alts from other cars that would bolt on/fit and have a higher output?
Anyone experience the ebay alternators long term?
EDIT: Car is manual.
Old 12-19-11, 04:37 PM
over40driv
over40driv's Avatar
The strength of the battery is just as important as having a higher output alt., and will protect the investment your spending on it. Buy a h.d. battery.
Old 12-19-11, 04:41 PM
over40driv
over40driv's Avatar
SC300 maybe easy to change, but the sc400 is a lot of work. Since I have down graded my stereo, I went down in the size of my alt., alot easier to install, and lighter.
Old 12-19-11, 06:09 PM
Kalogerus
Kalogerus's Avatar
I believe diff years have diff plug shapes too. If your plug is different you MIGHT be able to get the plug that fits and replace yours with it. You'll have to pull the wire all the way up through the space between the suspension and the intake. See the wires and the wires of the plug that fits and confirm the wire colors.
Also you may consider getting the upgraded battery too. I think its more important than the upgraded alt.
Good luck
Old 12-19-11, 06:29 PM
over40driv
over40driv's Avatar
IMO your better off to stay with the orig. p[lug in and they change about every two years.
Lexnek
Maintenance
04-20-17 05:41 AM
Kardinal
11-16-06 09:11 AM
dinobert
Maintenance
07-20-04 06:12 PM
alexamparo
Maintenance
10-10-02 03:49 PM
Quick Reply: Who has the upgraded alternator?
