Transmission feed/return
Looking under the hood, which transmission cooler hardline is the feed line? The one to the right or left?
I ask because I'm mounting an 11x11 B&M cooler and would like to feed the fluid to the top of the cooler, and let it return from the bottom. Thanks!
On all the Toyota setups I've seen, looking at the tubes coming out of the radiator, the inlet is on the passenger side. The outlet is on driver's side.
It would be easy enough to disconnect the passenger's side line and run it into a bucket to double check.
