Need some help quick: Transmission removal
Old 06-04-10 | 09:23 PM
LEXXIUM's Avatar
LEXXIUM
Try to loosen up all the bolts, and start them a little at a time and make sure your tq converter sits flush/flat on the flexplate, it has to go in perfectly straight.
Old 06-04-10 | 10:15 PM
attzor's Avatar
attzor
Ok, so after I read your post 15 minutes ago, I went down and tried it... 6 hours of ****ing with those bolts and all I had to do was loosen the other ones..
Old 06-06-10 | 10:02 AM
CRuby's Avatar
CRuby
Haven't been on for a couple of days, so sounds like you're making some progress. If you haven't figured it out by now, CCW = Counter-Clock-Wise. Not much play in the bolt holes, so install everyone one, loosely at 1st. Torque them after all installed. While you're under the trans can you check the position of wires on the O/D speed sensor (located at forward left side). Who ever messed with my trans before broke the plastic on the wire harness, so all I have are 2 loose wires (pink and green) with no plastic connector. When connecting to the trans, which color wire is toward front of trans, pink or green? Good luck on the torque convertor bolts!
Old 04-13-18 | 05:45 PM
2jkidd's Avatar
2jkidd
Originally Posted by attzor
Ok so I have the trans all lined up, semi bolted on, before hand, I lined up the torque converter bolt holes with the flex plates, now they aren't lined up. Does anyone have any suggestions on lining these up? and is there anyway to spin the torque converter from the outside of the trans?
How did you line the torque converter up with the flywheel??
marvin5881
03-23-19 02:06 AM
Clear
SC- 1st Gen (1992-2000)
03-27-16 10:41 PM
kez
08-03-10 08:15 PM
RedSC
GS - 1st Gen (1993-1997)
04-01-09 06:54 PM
DRFTSC400
02-16-09 10:43 PM
