na-t building beginning
carrillo rods
CP pistons
supertech valvetrain
GT3788
AEM or map ecu(what would your choice be and why)
virtual works manifold
4" down pipe
tial wastegate
hks BOV
hks fuel rail
850cc injectors
precision intercooler
titan stage 2 auto tranny
TMS 272 vvti cams
hks camgears
I know im missing a few things
Would the hks DLI work with my car if not what should I run
Would the supra aftermarket radiator work with my motor
Anything else im missing lemme know
CP pistons
GT3788
4" down pipe
tial wastegate
hks BOV
hks fuel rail
850cc injectors
TMS 272 vvti cams
hks camgears
go Aem, looking at your other parts you dont want to mess with map ecu with injectors like that.
you must be goin for crazy power if you are doing rods and pistons. may want to up the injectors or drop the rods and pistons. Use a Dli if you are keeping the stock TT coilpacks.
I have most of these parts. Just need help with not purchasing certain components that arent corect for my car(radiator and DLI). Im running a GE motor not gte motor. Would the TT coil packs work instead of the DLI. My horse power goal is about 650whp.
you should use the 2jz-ge vvti coilpacks and ignitor, or just stick with the distributor.
with the vvti coilpacks or the stock dizzy you shouldn't need a Dli.
you can't use TT coilpacks unless you get a front facing intake manifold, but it will require a DLI with the Aem so its all around better for na-t to just go vvti coilpacks.
thanks looking into a intake manifold now..since vvti and now vvti head internals are I dentical would a supra intake manifold be a direct fit for my motor. Could I also run a after market fuel rail for the supra.
Would I need a rear end to optimize my builds performance,if so which would you guys recommend
you can't use GTE fuel rails or manifolds, they are not interchangeable with the GE. we all wish they were though. The stock GE rail is good for quite a bit of power with some large injectors and a fuel pump. There are companies that make rails for na-t, just do a search and make sure its for na-t 2jzge
