SC400 + 1JZ + 1JZ AC compressor = Need your help!
Old 06-18-10, 09:37 AM
Dx3
Dx3's Avatar
Default SC400 + 1JZ + 1JZ AC compressor = Need your help!
Guys,
I have a 1JZ in my 92 SC400 (bought it like this.) Anyway, it looks like the installer welded the SC400 lines to the 1JZ compressor. So now, I didn't have a low pressure valve to refill my freon. From what I understand, the low pressure valve was on the SC400 compressor. I know it is over by the pass firewall in the SC300.
So how do I refill the AC with welded SC400 hardlines running to the 1JZ compressor?
Jonny
Old 06-18-10, 10:08 AM
93MSB
93MSB's Avatar
there has to be a fill port somewhere
why would the installer waste the time to weld the lines on then have no way to fill it?
sorry no sc400 here so i dunno where they should be, but there should be one... or a 3rd grader did the install
Old 06-18-10, 11:38 AM
Dx3
Dx3's Avatar
Yeah you'd think so. It was done by Snap/Dynosaur and they are ZERO help in trying to fix issues. Their response when I call them is "I can't diagnose it over the phone. Bring it down here."
OK, let me go drive 5 hours for something you could spend 30 seconds answering I understand they don't make any money helping people answer questions over the phone, but you'd think with them doing the install that they would at least give me an answer...
I can't find the low pressure port anywhere
Jonny
Old 06-19-10, 07:33 AM
RED95sc
RED95sc's Avatar
Hold on a minute, when u say they welded the lines to the compressor, do you mean if you wanna change the compressor, the lines have to go as well?. if you cant find fill port one, you might have to get another 1jz compressor, and lines if you want ur AC to work. i have a 1jz compressor if thats the case
Old 07-29-10, 01:35 PM
Yahoo27
Yahoo27's Avatar
You can have a shop refill it through the high side, Thats what I will be doing once I change out my compressor since it's shot!
Old 07-29-10, 02:58 PM
Dx3
Dx3's Avatar
I was told that they sell these special flanges that they insert into the low pressure line that act as a fill port. I need to see if my mechanic is able to do it, or else if I need to bring it to someone who specializes in AC...
Thx guys,
Jonny
Dx3
Dx3's Avatar
Did yours come with welded lines too?
Jonny
Old 08-01-10, 07:46 PM
Yahoo27
Yahoo27's Avatar
No i think they were switched to sc300, not sure, i dont even know if its a 2jz or 1jz compressor.
Old 08-01-10, 08:50 PM
RyanV
RyanV's Avatar
i believe they are the same part...the difference would be R12 vs R134a compressors.
Old 08-02-10, 12:46 AM
BigManne
BigManne's Avatar
hmm i also bought my sc400 1jz swap from snap. wonder if they did the same thing to mine. my ac blew cold for a while then got warmer and warmer.
Old 08-02-10, 01:05 PM
Dx3
Dx3's Avatar
LOL - I would take a look and see. I have no idea why they do it the way they do? Why not just add a low pressure port to the line before they put it in? Or have the correct line made?
Does your speedometer work?
I am having my mechanic try to charge from the high pressure side to see if that works, but it's not always successful. If not, he is going to remove the low pressure line and have a new one built with a port...
Jonny
Old 08-02-10, 05:10 PM
BigManne
BigManne's Avatar
yea my speedo works but my tach is off about 1000 rpms though. i plan on replacing all my gauges with autometer at some point.
Old 07-27-12, 04:27 AM
Skyline18
Skyline18's Avatar
Seems as though Snap does an amazing job at doing some shoddy work. 2 of my cars came from them one i took the other was built by them and sold to me from someone else... i know this is on old post but now I can see i was not the only one
DeclanO
02-16-12 03:19 AM
MrFairlady
SC400 / 300 Classifieds
17
07-14-10 06:47 PM
Yahoo27
07-14-09 09:31 AM
LSEGHATCH
10-07-08 09:49 AM
uenolove
08-05-07 01:46 PM
Quick Reply: SC400 + 1JZ + 1JZ AC compressor = Need your help!
