In with the GTE
#48
meangreen1
Not bad. You doing the wiring yourself?
#49
So I visited 5 salvage yards today trying to find this connector I looked through many camrys and corolas even a es300 but none seem to have this plug, the one place that does have some obd1 sc's i believe the connectors the same. Guy wouldn't let me back there says your not cutting wires out what happens if I sell a car. I replied dude its a Junkyard no one wants this crap I just need one connector. And he showed me the door. So I'm at a stand still here I'm willing to pay someone for one anything need help/ideas lol
Connector all the way on the right--->
#51
Gspec Go back at night and get the connector....bring some raw meat for the guard dogs..
#52
sc51, i actually have a Toyota PDF of all their electrical connectors with OE #s, so you could use that to just buy the plug from the dealer. these ECUs all take the normal style terminals that you actually pin into the plastic plug you're talking about. they cost like 5-10$ from the dealer. i'm pretty sure this is what DrTweak does, and he probably has the same PDF.
this is what i did with my 1jzvvti swap. it was missing two big plugs from the body harness on the Chaser that were missing (obviously because i don't have a chaser, and the SC stuff doesn't plug right in, and i couldnt find a soarer harness)
I may actually have one of these plugs chillin in my garage, as i had a spare SC harness and cutoff/kept a bunch of the plugs off it it.
send me a PM if you want some help.
also, FWIW, it looks like the male side of that connector on the far right (pictured) is actually stuck into the female side of the ECU. when you look at the ECU like you have pictured there, you should only see the pins, not the actual plastic plug filling it in. see if you can get it out of there. does that make sense? you may already know this.
#55
Hey i have the ecu plug if you need it. pm me. Double check the star on the crank while you have the harmonic balancer off because if its not connected to the gear anymore your car wont start. Didnt want to go with a oem water pump?
#58
cartmill hey buddy you need to replace that oil pump too. there is no telling what kind of nasty **** is down in that oil pump.
i would make sure to get an OEM Toyota (Aisin) oil pump too. this is a vital part and i wouldnt skimp on quality on this one part.
#59
I understand your funds are low but the Oil pump is no J/K Please again i say please don't reinstall the Oil pump that came with the GTE, If your want you can use the one off your GE engine it works fine.
