In with the GTE
Old 07-21-10, 08:59 PM
  #61
99SC42
99SC42's Avatar
The last thing you want is not having enough oil pressure, do it right the first time my friend so you can get to enjoy your car.
GL
Old 07-22-10, 04:31 AM
  #62
SC51
SC51's Avatar
^ True /true So is it just swapping the front cases or do I have to to my oil pans off again?
Old 07-22-10, 05:27 AM
  #63
99SC42
99SC42's Avatar
You should be able to remove it , with the oil pan on but make sure you replace the O ring behind it.
There is an Oring between the Pump and the Block.
GL
Old 07-22-10, 08:00 AM
  #64
cartmill
cartmill's Avatar
yeah it just bolts onto the front of the block and the front of the intermediate oil pan.
just order the o-rings with it. they should only be a couple dollars.
Old 07-22-10, 10:19 AM
  #65
Ali SC3
Ali SC3's Avatar
I wish I did my oil pump now. time to repull the engine... j/k.
I thought you had to use the TT one because of the crank sensor.
I'm with everyone else on this one, old pump must be on its last limb.
Old 07-22-10, 11:28 AM
  #66
99SC42
99SC42's Avatar
Yes the VVTi engine that came out of his car has the same Oil pump.
Old 07-22-10, 11:54 AM
  #67
Ali SC3
Ali SC3's Avatar
ahh got me again . one of these years i'll catch something you missed
Old 07-22-10, 12:52 PM
  #68
99SC42
99SC42's Avatar
LOl haha and you can replace the Oil pump while the engine is in the car , the main thing is removing the Crank pulley once that's remove it's really easy.
Old 07-22-10, 03:41 PM
  #69
SC51
SC51's Avatar
^ KK thanks for the replies guys Ordered one today so thats the last thing on my list to get then shell be on her way into the engine bay.
(Still NEEED the E10 Connector with leads!!) Having no luck finding one or buying it.
Old 07-23-10, 04:53 PM
  #70
StiCk3
StiCk3's Avatar
quick question about those turbos you have. Are they CT20 turbos or CT20As? Should be cast on the compressor housing. Trying to get a straight answer on this
Old 07-25-10, 01:24 PM
  #71
SC51
SC51's Avatar
StiCk3 quick question about those turbos you have. Are they CT20 turbos or CT20As? Should be cast on the compressor housing. Trying to get a straight answer on this
^Mine were the CT20A's
Old 07-26-10, 10:39 AM
  #72
qksl2
qksl2's Avatar
I have a complete Aristo harness and ECU if that'd help you. I've found that with an ECU patch extension harness, it fits alright in an SC with a GTE.
lookin' great dude.
Ian
Old 07-26-10, 03:40 PM
  #73
SC51
SC51's Avatar
qksl2 I have a complete Aristo harness and ECU if that'd help you. I've found that with an ECU patch extension harness, it fits alright in an SC with a GTE.
lookin' great dude.
Ian
^ Thanks ya I actually ordered the e10 w leads from Dr Tweak. Your car looks awsome in the sig pic.
I have all the schematics for the Aristo ecu if anyone has one or a link for the BIG GREY body plug that'd be awesome!
Old 07-26-10, 05:35 PM
  #74
SC51
SC51's Avatar
O2 sensor- Stock JDM uses a 2 bolt flange type, Is there a screw in type I can use?
Old 07-26-10, 08:28 PM
  #75
StiCk3
StiCk3's Avatar
ours uses the same flange, just make sure the pins for the sensor plugs match up. If you can pull the part number off the old O2 sensor and pick one up from toyota or where ever.
Quick Reply: In with the GTE
