In with the GTE
#76
StiCk3 ours uses the same flange, just make sure the pins for the sensor plugs match up. If you can pull the part number off the old O2 sensor and pick one up from toyota or where ever.
#77
you can use the old screw in type off the '99 and splice them into your new wiring harness as long as they have the same number of wires (you will have to do it anyways with a universal). I think both the '99 ge and the gte are heated sensors, but if the ge isn't heated (only 1 wire like the older sc's) then universal is the easiest way.
#78
![](http://farm5.static.flickr.com/4154/4835153770_512534bd2f_b.jpg)
I'm probably going to get banned since it has our shop on it, but I don't have time to PS it out so I guess I made my bed. Thank Aaron for this thing!
Ian
#79
Ali SC3 you can use the old screw in type off the '99 and splice them into your new wiring harness as long as they have the same number of wires (you will have to do it anyways with a universal). I think both the '99 ge and the gte are heated sensors, but if the ge isn't heated (only 1 wire like the older sc's) then universal is the easiest way.
Ian
Ian
*Update replacing oil pump does require pulling pans off
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
#82
Ian
#83
Some of the odb1 supra TT use the 3 wire o2 sensor. Its been a while but I know the 3 wire screw in type came on some year of the supra. easiest would be to get the universal, no hunting through toyota manuals and it will be cheaper.
#84
^ True looks like universal is the way to go, also updates came to a stop when my friend from Toyota never showed with the figp sealant
So in a couple days ill have a day off and try to button up the whole motor also noticed I was missing the crankshaft seal from my gasket kit. Also whats the purpose of the star thing on the crank sprocket I know there's a notch in it but why is it necessary?
#85
#89
qksl2 Make sure to TIG tack it to the back of the crank timing belt cog, they sometimes come loose.
Ian
Ian
soarer13oy
Yeah me neither. Sometimes that star separates from the gear and this will cause your car not to start. Also install the hybrid harness before you drop the motor in.
