In with the GTE
#92
#93
nextlevelcoupe full rebuild, top to bottom..what i heard from my mechanic, is that there is no easy fix for sludge!
*New oil pump is on, pans are back on just waiting for rear part of waterpump to arrive so I can do the timing.
#96
Yeah, it breaks stuff down. Make sure to check the clearance on all the lifters. I've found there to be a direct correlation between sludgy jap motors and valve lash issues.
Hey if our sigs were next to each other, and our cars run, they'd crash into each other at a very high rate of speed.
haha
Ian
haha
Ian
#98
qksl2 Yeah, it breaks stuff down. Make sure to check the clearance on all the lifters. I've found there to be a direct correlation between sludgy jap motors and valve lash issues.
haha
Ian
haha
Ian
ujs2slow nice motor im sure you will enjoy this thing boy becareful tho cops lol.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I just try an stay on the D L now
#99
Ok so ive been to bothe Autozone and Advanced and cant get the rite o2 sensor Supras are either using the flange type or there 4 wire, mk3's are 4 wire as well, ive tried for an NSX too but nothing, I looked up a 92 sc300 and they use a one wire. My JDM motor uses a 3 wire 2 blacks and 1 white, I'm guessing the blacks might be grounds so could I use a one wire?
#101
http://www.google.com/products?q=3+w...or+toyota&aq=f
looks like some camrys and toyota trucks had them too. 90 supra one may have a flange, not sure.
#102
stockhatch Nissan Altima? According to Wanganstyle, he used one from an Altima. Not sure what year though...
Ali SC3 http://www.google.com/products?q=3+w...or+toyota&aq=f
* Updates are water pump and rear housing is hooked back up, D day is tomorrow I'll try and get the timing done and drop it in.
