In with the GTE
#106
soarer13oy Man it looks beasty
stockhatch Nice! So have you sorted the wiring already then?
#108
qksl2 Did you try using your stock mounts?
Ian
Ian
*not too many updates just tranny mount is bolted still need to connect drive shaft, shifter linkage used off SC tranny, but it doesn't like to work with the gated shifter so its out for now, Pulled main ecu harness inside, just trying to figure out my body plugs since there not in any 99 SC ecu diagrams, A bit of work more to do before a start attempt.
#110
Nice build looking forward to seeing it finished. Quick question though, did you use the same manifold from your GE onto the GTE? I'm new to these engine but I thought they were alittle different??? Thanks
#111
JohnMatt Nice build looking forward to seeing it finished. Quick question though, did you use the same manifold from your GE onto the GTE? I'm new to these engine but I thought they were alittle different??? Thanks
***Update at a stand still now relizing I cant bolt by drive shaft up to Tranny, the bolt holes looked identical but there off on the output flange ever so slightly
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
#113
*UPDATE* start attempt today didn't go as planned. I wired up what I needed (I think) and added fluids. (noticed I have like no oil on dip stick, tip had a tiny bit and thats with 5+ quarts no leaks). Any way connected Batt and my fuel pump is on at all times even without key, and it wont turn over starter didnt even fire, Fuse box shows the "ETCS" fuse keeps blowing![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
-have 12v mod done already-
E 10 connections
E10 99SC
-1 IGSW IGSW E19-9
-4 STP STP E18-6
-6 W warning indicator W E19-6
-7 R park/neutral switch STA e18-2 Shift lever P N ign switch start
-21 D1 Fuel pump ecu D1 E19-4
-22 FPC Fuel pump ecu FPC E19-5
-24 MREL Efi main relay BM e19-7
-31 +B Efi main relay BM e19-7
-32 Blank Grounded
-33 Batt thick black wire w red stripe
Big Grey body plug
-22 pwr to ignitor coil BM e19-7
-53 linked to ignotro coil VSV possibly power link- Batt const.
-14 Ground/Engine Grounded
-23 Ground to engine Grounded
(engines Grounded as well)
Guess I'm not as good with wiring as once thought
Help please
E 10 connections
E10 99SC
-1 IGSW IGSW E19-9
-4 STP STP E18-6
-32 Blank Grounded
Big Grey body plug
#114
with a dry engine that's been sitting around, you'll need more oil than 5 quarts on these. I put in 7 quarts on my first start up then let it sit and run for 10 mins. After that, changed the oil and the filter (should be about 5 quarts going in this time) and then ran it for a few hundred miles and repeated. Do this 5 times and then you can go on regular intervals (i go with 1000 miles on mine)
#115
I would not recommend overfilling. With the windage and frothing, you are going to aerate the oil pretty badly which will actually work against you regarding lubrication.
Also if you overfill it by too much, you could theoretically block the turbo return. Then you back oil up into the turbo and blow past its seals. Just run a cheap oil through a couple heat cycles, drain, and change. You could do that a couple times with cheap oil of you are really paranoid about cooties.
PS, sorry I am not much help with wiring. I am a hands on "gotta have it in my face" person when it comes to complicated wiring. Good luck man, I know there are some wiring gurus on here that will help you out.
#117
#118
for the starting, are you sure you got the wiring for the main relay right.
with the 12v mod, the pump should only be on with the key in the ignition.
#119
^^ Interesting ya I put in like 5.5 and its at the low mark so I'll add some more before the start.
I didn't touch any relays just traced wires on my old harness that went from the body directly to the ecu, alot of wires I cant identify because I don't have all the schematics. I think I just wired to many things together, I'm going to try hooking less things up to try for a start.
Ali SC3
