1jz OE part numbers to add
I found this helpfull and wanted to share the info here as well.
1JZ Part cross reference
Cooling System
Toyota Part number - Description
16400-46210 - Radiator (for hydro fan)
16371-46020 - Water pump Pulley (non hydraulic fan)
16361-46060 - Water Pump Mechanical Fan
16210-46030 - Water Pump fan clutch
16100-49845 - Water pump (non hydraulic fan)
16912-46020 - Hydraulic Fan (Shroud)
16960-46020 - Hydraulic Fan (motor)
16911-46010 - Hydraulic Fan (Fan)
16929-46010 - Hydraulic Fan (Actuator Solenoid)
89429-32010 - Hydraulic Fan (Temperatue probe)
16913-46020 - Hydraulic Fan (Fan bracket)
89257-14010 - Hydraulic Fan (ECU)
16939-46010 - Hydraulic Fan (Waterpump Pulley)
16090-49017 - Hydraulic Fan (Waterpump)
16927-46020 - Hydraulic Fan (High pressure line)
16571-46030 - Upper Radiator Hose
16572-46100 - Lower Radiator Hose
90916-03092- Thermostat
Engine Mechanical
13101-88400 - Pistons
13201-46030 - Rods
13011-88400 - Rings – full set
11704-46020 - Bearings – crankshaft
13204-46020 - Bearings – connecting rod
15100-46030 - Oil Pump
11115-88410 - Head Gasket
04111-46032 - Engine Gasket kit
90910-02102 - Head Bolts
90201-11018 - Head bolt washer
17177-88400 - Intake manifold gasket (to head)
17179-88400 - Intake manifold gasket (to manifold)
17173-88400 - Exhaust manifold gasket (need 2)
11213-88400 - Cam cover gaskets Intake
11213-88400 - Cam cover gaskets Exhaust
90105-06133 - Cam Cover bolts x16
90210-07001 - Cam Cover bolt washer x16
90916-02305 - Serpintine Belt
13568-49025 - Timing Belt
16620-46020 - Serpentine belt tensioner
Engine Peripherals
78180-1B090 - Throttle cable
12361-42050 - 89+ Motor mounts
12315-88400 - Engine Brakcet LH
12311-88400 - Engine Brakcet RH
Drivetrain
13405-46030 - Flywheel
90910-02103 - Flywheel bolts
31250-14183 - Clutch Pressure plate
90363-12002 - Clutch Pilot bearing
90363-45012 - Clutch Throw out baring
90119-08302 - Clutch pressure plate bolts
31111-14110 - Bellhousing
33403-29135 - Speedometer drive gear for 4.1 diff
Power Steering
44403-14020 - Power Steering high pressure line
90401-16014 - Power Steering Union Bolt
04446-30120 - Power steering pump gasket kit
44320-14231 - Power steering pump
Engine Electrical
89420-24040 - Map sensor (1JZ)
89421-12111 - Map sensor (2JZ)
89615-22040 - Knock sensor
90919-05006 - Crank position sensor
90919-05007 - Cam position sensor
89452-22080 - Throttle position sensor
89424-28010 - Intake air temp sensor
89422-20010 - Water temp sensor
89465-29435 - O2 Sensor
89621-22030 - Igniter
27060-46010 - Alternator
22270-46070 - Idle speed control valve
Filters
90915-20001 - Oil Filter (Same as V6 Camry)
23300-46050 - Fuel Filter
17801-46060 - Air Filter (Same as Supra/Soarer)
JZX100
90919-01194 - Spark Plugs (denso?)
90919-01195 - Spark Plugs (ngk?)
JZX90
90919-01180 - Spark Plugs(denso?)
90919-01181 - Spark Plugs(ngk?)
info was found at jzx100, hope it helps.
Cooling System
Engine Mechanical
13201-46030 - Rods
Engine Peripherals
Drivetrain
Power Steering
Engine Electrical
Filters
JZX100
JZX90
1jz, 2330046050, 7m, 8942024040, coolant, denso, exhaust, gasket, iscv, map, number, part, sensor, speedometer, temp
