What WG spring should I use?
1JZ, single turbo, tial 44.
What waste gate spring pressure would be recommended for a street driven 1JZ. looking to make in the 500-600hp range in the end. Right now my Tial MV-R has a 1.0 bar spring. Going to the dyno soon and want to stay in the 400's hp for now. Should I get a lower spring?
Thanks.
Thanks.
Basically I need to know what others experiences are. I would like a spring pressure that will keep me under 400 but still be able to reach 500-600hp. (edit) reach 500-600 with a ebc.
thanks.
thanks.
1 spring wont do that. If you want that kind of adjust-ability, go with a Synapse WG..otherwise your going to have to settle with a 12-15psi spring, and get a boost controller. But basing your HP on just the WG spring is almost impossible to do without knowing what other mods have been done with the engine...cams/manifold/turbo specs/injectors/etc..
well my mv-r has a brown, maroon, grey springs. which make it 1 bar. looks like i will take out the brown which will lower it to 0.8 bar. to start. or pull out the grey to make it a 0.6 bar. and use my boost cont. to go from there.
thanks.
thanks.
ashtray
Performance & Maintenance
02-12-10 01:09 AM
