oil filter
Old 08-05-10, 08:54 PM
JJAUTOWERK
JJAUTOWERK's Avatar
Default oil filter
what oil filter do i buy for a 1jz gte? Is it the same filter as a regular 2jz ge?
Old 08-05-10, 09:07 PM
S142jz
S142jz's Avatar
Your should be able to use the 2jz filter with no prob.
So even the purolator 10241 will fit.
Old 08-05-10, 09:42 PM
vangb2
vangb2's Avatar
All JZ are interchangable
Old 08-05-10, 10:27 PM
aka paco
aka paco's Avatar
yeap even the 1uzfe and 3uzfe use the same filter as the 2jz/1jz
Old 08-06-10, 10:17 AM
JJAUTOWERK
JJAUTOWERK's Avatar
oh ok thankyou all, if all jz are interchangeable then an ac compressor should fit from an is300 on my car then right?
Old 08-06-10, 04:09 PM
StiCk3
StiCk3's Avatar
idk about an IS300 compressor, but an SC300 one will bolt up as long as you didn't use the 1JZ compressor and adapted lines.
Old 08-06-10, 04:23 PM
sayayin
sayayin's Avatar
I bought K&N oil filter for my 1jz HP 1002.
Old 08-20-10, 12:36 AM
Irslopra2
Irslopra2's Avatar
does ne1 really need higher flow rate out of their oil filter? hate to rain on ur parade w/ the k&n filter, but in my opinion i say take that thing and put it where it belongs, in the trash. go get ur self a wix filter. i know u didnt ask nething about it, but the only place on a motor where u may want to sacrifice a little bit of flow, is with your oil. that and i just think k&n is trash to begin with. me and every1 i know ONLY runs AEM and Wix filters depending on the application.
Old 08-20-10, 06:16 AM
OneJay
OneJay's Avatar
I just use OEM YZZ-D3 filters. They work just fine.
kimsey
12-01-15 03:00 PM
jimbosr1
09-06-13 06:34 PM
jagtoes
ES - 5th Gen (2007-2012)
05-01-09 08:57 PM
jefferino
SC400 / 300 Classifieds
10-31-08 07:22 PM
moya
RX - 1st Gen (1999-2003)
29
06-09-06 11:48 AM
Quick Reply: oil filter
