Water pump hose keeps coming off
Old 08-06-10, 08:06 PM
ch1llwill
ch1llwill's Avatar
Default Water pump hose keeps coming off
Dont know what going on ,i changed the clamp,also water pump was replaced days ago along with timing belt,1jzgte twins.stock still.clutch fan.
Old 08-06-10, 08:15 PM
scviolence
scviolence's Avatar
is the hose to big???only thing i can think of since you already changed out clamp....in other words is it factory..
Old 08-06-10, 08:21 PM
ch1llwill
ch1llwill's Avatar
Yes factory hoses,its come off 2 times already the one from water pump.and the one from top of radiador came off once only.ireplaced the clamps with srew types and am watching it and i can see it making its way off again (the water pump hose)
Old 08-06-10, 08:28 PM
ch1llwill
ch1llwill's Avatar
Originally Posted by ch1llwill
yes factory hoses,its come off 2 times already the one from water pump.and the one from top of radiador came off once only.ireplaced the clamps with srew types and am watching it and i can see it making its way off again (the water pump hose)
this started happening after timing belt,water pump,was replaceddays ago.
Old 08-06-10, 08:48 PM
SChema
SChema's Avatar
Worst case get some emery cloth or sand paper to rough up the water pump fitting. You could also pick up some of the silicone belt and hose dressing to help it adhere to the water pump and radiator.
Old 08-06-10, 09:10 PM
ch1llwill
ch1llwill's Avatar
so you dont think its nothing else?the radiator is not too old and thermostat seems to be ok???
Old 08-06-10, 09:30 PM
SChema
SChema's Avatar
If nothings cracked or collapsing on itself, I really can't think of anything else. Another thought could be that the hoses were degrading from the inside out getting saturated with coolant rendering them slippery when in contact with plastic and metal.
Old 08-06-10, 09:32 PM
ch1llwill
ch1llwill's Avatar
yea amkes sense,thanks bro.
Old 08-07-10, 04:29 AM
stockhatch
stockhatch's Avatar
I know its rare, but I almost wonder if its got a HG leak and is pressurizing the coolant system.
Old 08-07-10, 06:05 AM
SChema
SChema's Avatar
I've only seen this happen once around my area, it is a possibility though. Let's hope it's not the case.
Bocatrip
07-04-16 04:10 PM
Superfast1
13
07-15-15 02:46 AM
MarcoP
01-30-14 08:34 PM
wcoastls
17
07-15-11 04:17 AM
dejacky
12
12-22-09 08:17 PM
Quick Reply: Water pump hose keeps coming off
