Thermostat housing for Aristo swap?
I saw in this thread, here, that you have to get the Supra thermostat housing for an Aristo swap. This is the first and only mention of this I have found. Is this optional depending on certain factors, or a must?
Input is appreciated! I am trying to preorder everything as my engine is stateside and should be to me in a week or two.
Thanks
Thanks
The housing can be interchanged but you have to drill the bolt hole bigger and also it will be facing a different direction. You will have to do a little fabricating to make it work as I did mine.
