Car died on the road. Starts-then dies immediately
Old 07-17-13, 07:44 AM
  #31
Chasrb
Chasrb's Avatar
Well it still has not died. Took it to a mech and he checked the cam and crank sensors - all within the specs.
I thought of replacing the fuel pump just for replaceing it, Does the pump have the history of running and then failing then after a 10 min or so of being off then start working agin? It's an easy swapout on the fuel pump if I need to do that.
Have there been PCV issues with this engine? I remember on my firebird the car had problems if the PCV was bad or clogged.
One thing I did not do right after the Fuel ECU replacement was to pull the ign fuse to restteh fuel ecu - so I read somewhere. I did finally do that and so for the car is still tunning ok... can't figure this out yet.
djeddieo
04-10-20 07:32 PM
SCFactory
02-15-16 04:54 PM
lexdud
03-27-12 05:40 PM
Quick Reply: Car died on the road. Starts-then dies immediately
