Solid answer on Q45 TB on GTE ECU...
Ok starting to finish up my na-t finally, and need a 90mm TB without cutting off my arm. I have been searching and reading usless threads for 2 days now, and cannot find a solid answer regarding the Q45 TPS. As some may know, I will be running my NA-T on a GTE ecu, but would like to know if the GTE ecu is able to PROPERLY recognize the Q45 TPS, and I also need a wire diagram.
I know there is an adapter available, but my current budget is limited due to starting a completely different part of my SC's build, but until that time (after the new year) I need my SC on the road. SO, if there is anyway possible to run the Q45 TPS on the GTE ecu please let me know. All I have found in my search so far is a bunch of yes's and no's, but no SOLID answer.
for a mk3, but Its similar: http://www.supraforums.com/forum/sho...d.php?t=321855
and this one for an n/a: http://www.supraforums.com/forum/sho...d.php?t=417180
Location: Sideways on the Yellow Brick Road! < Thats KS!
Just a FYI, the Q45 TB is not really a 90mm, I dont know who started this whole 90mm thing but its all over the internet. The OD measures 90mm, the ID, which is what matters measures 85mm. Its still a nice upgrade and the TPS will work from what I understand. I happen to have one setting around as well.
when i put my q45 TB on my intake manifold, i just used the greddy TPS adapter, so that way i could just use the stock TPS, use thread lock because the little allens will back out
I'm going to order the adapter tomorrow just to skip the haggle, plus my SC hasnt seen pavement in almost 4 months now, and its time to get her back on the road.
