Crazy 3000rpm Idle
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I have a 92 SC300 5speed with no engine mods with about 140k on the clock, tune up about 5 months ago. Timing belt NGK plugs and wires all that. Even clutch, cap, and rotor button.
Did a lil fast driving on the highway to work and when I got off the highway my SC was stuck at a 3000rpm idle. I cleaned my idle control unit and no change. I purchased a new unit from a dude on craigslist and no change. When I unplug the TPS and MAF the idle drops to abot 2000 to 2500 and gets rough til i plug them back in. No change when Idle unit is unplugged if there is pose to be a change from that. Swapped the ecu out, the tps and the maf with no changes. Someone said it could be the PCV, I dont know need help for my love asap.
I checked all that and everything looks as it should. I cleaned the throttle body and maf sensor and the idle is down to 1800rpm. Im running out of ideas.
TPS can fail too.
Check this link for reference how to test your TPS.
http://www.supraforums.com/forum/sho...d.php?t=450071
I swapped the TPS and there was no change, and I did the spray test also but forgot to mention with no change, Honda boys do know a lil something got that form one, lol. But as 3Rotor said im gonna check my throttle body again. I did recall seeing some slight gap (about a hair) but i was thinking it was suppose to be like that cause i was working it with my hands and it wouldnt close 100%. I also pressed on the blade and it didn't try to close that small gap either. If thats the case what would cause that gap. Im gonna pull it off the car today about 6. Its hot in VA.
I will take pictures when its off.
So is this amount of gap required or is this my problem. I put some pressure on the blade with my finger and the gap didn't close. All the screws for the throttle cabble and stuff is in the original position.
![](http://i209.photobucket.com/albums/bb277/cupidgotswagga/SANY0568.jpg)
![](http://i209.photobucket.com/albums/bb277/cupidgotswagga/SANY0569.jpg)
After all the cleaning and all the car idles at 1100 now but comes down to that after a slow deent from about 1500. Its still not right but better. im thinking of replacing the entire upper intake and see it the kills it. Im talkin the throttle body and all. I just the car back in order asap. I've done all that i can think to do. I have a check engine light ima get checked soon as this guy gets back to his shop monday if it isn't straight by then.
xtahoex
17
05-15-17 09:51 PM
