Out with the Aristo tranny
The tranny is supposingly rebuilt with low miles. Last picture shows a small crack above the star screw (only flaw ive found).
Couple questions
1. I cant use this flywheel correct, ineed 1jz?
2. while in nuetral its difficult to spin driveshaft, it moves its just real tight.
Couple questions
It should spin fairly easily even dry. Mine does. Is the crack really a crack, or just casting lines?
Also, if it came off of a 7M car, you will need a bell housing as well as a 1JZ/2JZ flywheel. Notice how the flywheel only has 6 holes as opposed to the JZ 8 holes.
You will also need a cable to electronic speed sensor sender. You can buy it from Driftmotion or Marlin Crawler.
stockhatch Congrats man! Don't forget you can order the Soarer extension parts from Carson Toyota or Champion Toyota. I got mine in the other day.
^Ya you cant see it in the pic its a small crack above the screw.
As far as not getting a custom driveshaft made is there anyway to mate the 2?
No, the extension I have is 1" farther back than that. When you manipulate the geometry of the shifter like you are planning, your throws get a bit weird. The shifter moves forward and back, but also up and down. Its not going to be the greatest shifting feel if you do that, and these trannys aren't known for their superior shifting feel as it is.
https://www.clublexus.com/forums/3242324-post10.html
I think those are the part numbers. I dont remember what I used when I ordered mine to be honest. Regarding a short shifter, I believe Driftmotion sells one that will work, though I dont know if it will move the shifter location compared to a stock shifter...I also cant vouch for the quality of the shifter itself since I have not heard any feedback on it.
