Out with the Aristo tranny
#31
When you drill the hole in the firewall for the center of the master to poke through, I would use a knockout cutter as opposed to a holesaw. That way you can drill a relatively small pilot hole which is much easier that manhandling a large holesaw. A holesaw will be a pita to maneuver in that tight space.
#32
K Thanks ya I assembled the clutch pedal by hand last night, god that spring sucks lol. I guess my only other question is the master cylinder, when I take the cap off theres this rubber thing floating around in there, do I have to leave that in there?
#34
^ K Thanks.
*Install tonight took longer than expected and was a ***** to do just like everyone says I also put a bolt through the clutch sensor hole for extra security. Definitely different driving auto with 3 pedals, the brakes close to the gas.
I'll post pics if any ones interested, just looks like any other manual setup
#36
Almost feel like I shoulda saved some $ and went with the stocker. Someone enlighten me but other than being yellow and engraved they look identical, I mean to weight, thickness of metal, and the "straps" that are said to snap under pressure on the stock plate, the Act is identical...
There must be something I don't know in how these are made..
#40
looking great bro. yes the gear ratio will be short swap a 3.92 or 3.26 rear diff and have fun. I had both 3.26 from an sc430 and 3.92 from 92 sc4 but I like the 3.26 better longer gear .
#44
those parts are discountinued no longer available, i ordered a set from job and after a month toyota dropped the order and call my manager and told he those parts are no longer available.
#45
^ thanks fellas ya itll be a while before I can afford a rear end, want to go with a new turbo/exhaust setup next.
I read on a recent post someone said the 98-00 sc3/4's had a 3.26 read but maybe thats wrong? 430 rear must be pretty hard to find eh.
When its a cold startup like 30 or below I hear like clunking sounds from the bellhousing but then it goes away..? BTW im on a stock disc.
