Out with the Aristo tranny
#46
Bled the CLutch, Took her for a spin, the R154 Deff makes some noises
But it is pretty fun to drive. Feels even faster now and the waste gate is extremely loud threw the open automatic hole. Time to fill holes and dynomat![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Don't know if this applies to any other years but I looked up the 1999 SC300 Diff Ratio and its (3.27) Heres the link where I found the info http://www.cars.com/lexus/sc-300/1999/specs/
quickGS300 looking great bro. yes the gear ratio will be short swap a 3.92 or 3.26 rear diff and have fun. I had both 3.26 from an sc430 and 3.92 from 92 sc4 but I like the 3.26 better longer gear .
#49
quickGS300 GS400 and SC400 for 98 and up 06 SC430 are 3.27
The 92-97 SC4 are 3.92 and the 98+SC3 are 3.92 also.
The Stock W58 is 4.08 AND auto is 4.27 for 92-97.
meangreen1 Cool swap. Cant wait to see what your plan is for that shifter. I also would like to see pics of it in each gear.
#50
The pics are in order N-1-2-4-5-R. Shifting is very important to me and when I get the money I'm just going to have to have the housing sent to Driftmotion and have the car down for a while
.. I mean what I did works but it still doesn't sit how would idealy want it to and the shifts are kinda up/down..
#51
I would try calling Carson Toyota or Champion Toyota. Last I heard they still had some Soarer stuff in stock. You may get lucky and find one and avoid paying all that money to driftmotion. Let me find those part numbers...
EDIT: These should be the part numbers you need.
Housing, Shifter (33521-24040)
Control Shift Lever (33570-24010)
#52
#53
quickGS300
Those parts are N/A .
#59
BartleDoo You'll get used to the shifter lol. Mine is the same way.
meangreen1 If I had the specs, I could make one up. I just need to know how long to make it.
#60
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
92-97 SC300
6 cyl, AT (4.27 ratio)
6 cyl, MT (4.08 ratio)
98-00 SC300
92-96 SC400
8 cyl (3.92 ratio)
97-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
w/o turbo; (4.27 ratio) Limited Slip
w/turbo, MT (3.133 ratio) Limited Slip
w/turbo, AT (3.769 ratio) Limited Slip
97-98 MKIV Supra
w/o turbo; (4.08 ratio) Limited Slip
all taken from clubna-t
Heres what ive always went buy.
98-00 SC300
92-96 SC400
8 cyl (3.92 ratio)
97-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
97-98 MKIV Supra
