Normal idle for 5spd sc300s
Old 09-11-10, 12:01 PM
chelli
chelli's Avatar
Default Normal idle for 5spd sc300s
Hey guys, whats the normal idle for a 93sc300 5spd wifout the AC on? Mine seems to idle at about 900-800? Is that a little high? From my experience from other cars it seems to always run at about 750-700?
Old 09-11-10, 02:16 PM
ArodDaLob
ArodDaLob's Avatar
w/ the ac on, that sounds about right.
Old 09-11-10, 02:28 PM
wooziewest
wooziewest's Avatar
800-900 still seems reasonable. Mine has idled at what seemed to be 300 before ( don't even know if that's possible) until i blip the throttle. Then its around the 700-900 area
Old 09-11-10, 03:35 PM
2ndgen300
2ndgen300's Avatar
mines at about 1000 with the ac on, then 800 with it off
Old 09-11-10, 06:33 PM
ClearP
ClearP's Avatar
Mine is around the same 7-800 without ac, 1000 with ac
Old 09-11-10, 06:51 PM
TougeSC3
TougeSC3's Avatar
I idle at 750.
Old 09-11-10, 06:54 PM
Copilot
Copilot's Avatar
750-800 without AC
Old 09-11-10, 07:01 PM
DKJZZ30
DKJZZ30's Avatar
mines around 800
Old 09-12-10, 04:56 PM
chelli
chelli's Avatar
Thanks for the input guys, seems like mine should be borderline good enough.
Old 09-12-10, 05:51 PM
thatWESguy
thatWESguy's Avatar
750 - 800, if your idling low at 300 or so, check for a vacuum leak
Old 09-23-10, 03:22 PM
Cablendz
Cablendz's Avatar
Mines use to idle around 1000,, but ever since i changed the spark plugs and the vacuum hose gave me trouble,, it idles around 700
Old 09-26-10, 11:03 AM
SC30096
SC30096's Avatar
reset the ecu by disconnecting the negative terminal on your battery for about 10 mins or so, when i first got my car the idle was around 1000 after the reset its at about 750, i think it has something to do with the altitude and atmospheric pressure.
salimshah
03-31-16 06:06 PM
I8ABMR
12-17-12 03:08 PM
xtremex626
08-12-12 12:47 PM
GSquicksilver
06-11-08 01:25 PM
edbro
RX - 1st Gen (1999-2003)
09-29-07 09:08 AM
Quick Reply: Normal idle for 5spd sc300s
