Is this plug needed?
Old 10-29-10, 08:40 PM
soarer13oy
soarer13oy's Avatar
My climate control still worked its just that heat wasnt coming out when i turbed on the heater. IT was basically air.
Old 10-30-10, 02:20 PM
SC51
SC51's Avatar
Hmm I prob never hooked up the power wire for mine then, and its getting cold
Old 10-30-10, 06:27 PM
soarer13oy
soarer13oy's Avatar
Yeah its about time for that.
Old 10-31-10, 08:02 AM
SC51
SC51's Avatar
Well I fixed my climate control, havn't driven it so IDK if theres heat. But my heater valve plug looks different its only a 2-wire, I'm guessing just cross the wires?
Old 10-31-10, 11:59 AM
soarer13oy
soarer13oy's Avatar
Mine is just two wires as well. I followed what stockhatch posted and it worked fine.
Old 10-31-10, 12:11 PM
soarer13oy
soarer13oy's Avatar
Run the two wires the yb one is going to go with the yb wire(pin 7), and the rb will go with rb on pin number 2. Its the plug that is connected on the top near the heater core area.
Old 11-01-10, 03:10 PM
SC51
SC51's Avatar
Had some time to check out my valve today it seems to be always open but I bypassed it anyway. Heats only luke warm, I drilled a bunch of holes in my t stat for summer, I guess its time to change it out
Old 11-01-10, 08:13 PM
soarer13oy
soarer13oy's Avatar
So the valve was stuck open before you bypassed it? Mines gets pretty hot if i really turn it up.
Old 11-01-10, 09:22 PM
SC51
SC51's Avatar
I mean when I took it off I could blow through it fine, tested it tonight heats pretty good With my t stat mod how could its been my coolant temp hasnt been past 120, highest it ever got in summer was 165
Old 11-01-10, 10:58 PM
soarer13oy
soarer13oy's Avatar
Good to hear.
Old 01-08-11, 12:11 PM
joe diego
joe diego's Avatar
So do I remove this plug from my old 2jzge harness and connect it to my 1jz engine harness? Wouldn't there be excisting wires there on the 1jz harness. If so, what do I do with those wires?
Any info will help... Currently swapping to 1jz
Old 01-08-11, 01:30 PM
93MSB
93MSB's Avatar
the plug is there on a 1jz soarer harness, it's just on the opposite side of the engine bay since the 1jz's are originally rhd. you can remove the entire valve if you want to bypass that whole system
jayntee
05-31-13 01:21 PM
shhhmoke
06-09-12 10:14 AM
toyotasrfu
09-03-07 07:23 AM
lpolo69
GS - 1st Gen (1993-1997)
08-06-06 04:13 PM
UTA LS
08-14-05 10:31 PM
Quick Reply: Is this plug needed?
