View Poll Results: Is your SC400 faster without the MAF?
Yes
17
32.08%
No
9.43%
I think this is a stupid post
20
37.74%
Its impossible so I will not even accept it as a possibility
20.75%
Voters: 53. You may not vote on this poll
Unplugged MAF = More torque, gas, fun 92-94
#61
1JZ Single SC400
I have had the MAF unplugged for 3 days now, and it is an improvement over stock. The only thing I notice is the idling. It idles a little off, not bad, but noticeable. Its not as smooth as it was plugged in. I have deleted all three cats, and straight piped the exhaust, and a BFI with a K and N filter. I will keep it unplugged for a bit and check my mileage and maybe the odd idle will soon cure itself. Only time will tell. Mine is a 92 SC400, automatic.
#62
#63
It worked like an untuned carburetor car to me, misfiring sometimes.
Today I´ll do the 12v fuel pump mod, because my car starts, idle for some seconds and then shut off. (with the MAF plugged in by the way)
Maybe that is the problem that make it bogged between gears when I unplug the MAF. I´ll give it a second try, but when I tried it, I didn´t feel any improvement.
#64
#72
1JZ Single SC400
The results are in. The mileage has taken a little hit, maybe 20-25 miles total or a gallon of gas. It does run, speed wise and has far better throttle response, than with it plugged in. It shifts kinda funny, like slipping when I floor it, but overall it pulls very well , when the O/D is off and its in second gear. This is my results.
#75
So my two downstream O2 sensors are bad, and the two TPS's are going out too, so does this mean my MAF is probably not even working. My car hauls major *** and its all stock....?
I haven't tried this mod, although I will tonight.
