Tach adapter or resistor mod for a 2jzgte?
Yeah i just completed matching the wires from the 95 harness to the wire on the 99 plugs. Just gotta do some soldering. Il will post up the pin#s and colors for those who would like to do this mod once ive tested and have this working.
this is how the back of the cluster looks...The resisters are actually soldered on the inside of the the board.
you can see the solder right in the middle.
Hey nice work getting it that far man. It sounds like you don't have a tach signal at all, since it has not worked on two different clusters now. I would run a dedicated wire from the igniter at least temporarily to verify this. As for speedo, I would have to check the diagrams I have, though they are all at home so it will be later before I can look for you.
I actually have one. You know the diagram on the other post about swapping the cluster? Can you please show me which pins from the 95 harness goes to which pins on the 99 cluster i need to swap to make the tach, speedometer, and temp to work? I have everything and the cluster works except for these 3 things. Also, since the 99 cluster had PNRD321L i didnt wire anything to the 321
I probably have to tap the ignitor since jumping the resistors didnt work last time for the tach. Im in an auto so im not too worried about the tach.
Whats your email? Il send you the send you on excel how ive rewired it.
yeah the exterior. I dont really care for it that much but if i can get it to work that would be great. Im more worried about the speedometer and tach, but i would like everything to be working.
