Tach adapter or resistor mod for a 2jzgte?
#31
13D i dont have connected. 1c i dont have connected. 10b i have connected to 19c which is suppose to be violet. 11b i have connected to 20c which is suppose to be violet w/white. 9d i have connected with 9c. I dont think all the colors were the same as the ones listed on the schematic. For 1 C i had no wires there from the pigtail that i received with the cluster, although the pin next to it was orange, but that pin 2c i had connected with 20a. From the 95 harness i have nothing connected to 13c which is for the vehicle speed sensor
#32
It looks to me like 13D on the cluster should be the speedo signal. 13C from the 95 harness should go to 13D on the cluster from what I can tell.
For the tach, run a dedicated wire from the igniter to pin 9D on the cluster. IIRC, the igniter tach signal wire is pin 1 on the 4 pin plug. It is a small black wire.
#35
I know il test it later today and will post up results. For the outside temp. i have 19D connected with 14b. Both of which are suppose to be green wires. If thats correct and i should be getting a temperature reading then i guess my sensor is shot or something. Thanks stockhatch!
#36
Yea2jz is your cluster on the way? Was it from a 97 or 99? Lets hope the info from stock hatch works so you youll be set before the cluster gets in.
#38
Not yet I am sending Aliga the payment for the cluster tonight, He told me it was exactly like the one he sent you so I am asuming that its a 98+ because on a 97 the "PRND123" part is straight down like a pre 97 but on the 98+ they are some what gated like the shifter and thats what I want
#41
Yeah i saw it. Hopefully aliga would give me a good deal when i decide to get it. Il let you know as soon as im done with the wiring. Results would be up by tonight. Il keepp you posted.
#43
#44
#45
Its cool thanks stockhatch you mind if i buy u a case of beer? Well through paypal of course because my tach and speedometer works now.
yea2jz just use the excel sheet i sent you and put 13d from 99 cluster to 13c 95. For the tach i had to tap the ignitor exactly how stockhatch told me to.
