Tach adapter or resistor mod for a 2jzgte?
Old 09-27-10, 04:04 PM
stockhatch
stockhatch's Avatar
Default Tach adapter or resistor mod for a 2jzgte?
I know the 1jz guys just jump a resistor on the back of the cluster, does the same mod work for a 2jzgte, or do I have to run a tach adapter? I have not found a solid answer on this one.
TIA
Old 09-27-10, 05:07 PM
Guest
Guest
Posts: n/a
just did the mod for my aristo 2jzgte swap and your in luck cuz it works! =]
Old 09-27-10, 05:28 PM
Ali SC3
Ali SC3's Avatar
They use the same 6 channel ignitor (w/same tach signal) and it works.
Old 09-28-10, 05:03 AM
stockhatch
stockhatch's Avatar
Sweet! Thanks
Old 09-28-10, 11:37 AM
soarer13oy
soarer13oy's Avatar
I have a 95 which resistor do i bypass again? Do i have to cut off the resistor also?
Old 09-28-10, 11:49 AM
stockhatch
stockhatch's Avatar
You should be able to just jump the resistor. No need to remove it. I need to search myself for a 1jz thread that tells which resistor....
Old 09-28-10, 12:03 PM
stockhatch
stockhatch's Avatar
Hmmm, looks like R109 at least for the early cars like mine. Not sure on the 95...
Old 09-28-10, 01:16 PM
99SC42
99SC42's Avatar
I did R109 on my 95 and it's worked great, and when i went coil on plugs on my Na-t i did the samething to get my tach to work.
Old 09-28-10, 01:39 PM
stockhatch
stockhatch's Avatar
R409? I wonder what year it changed from 109 to 409.
Old 09-28-10, 03:12 PM
soarer13oy
soarer13oy's Avatar
Cannot find it. I do have the r73 bypassed doesnt work.
Old 09-28-10, 03:41 PM
stockhatch
stockhatch's Avatar
On a 95, look for R73. That is what i read here... http://www.supraforums.com/forum/sho...d.php?t=491045
Old 09-28-10, 04:16 PM
soarer13oy
soarer13oy's Avatar
Its not working for me. I might need a new cluster lol.
Old 09-28-10, 05:33 PM
stockhatch
stockhatch's Avatar
Awww man that sucks. Did you try R109, r409, or R73?
Old 09-28-10, 05:41 PM
soarer13oy
soarer13oy's Avatar
I tried r109 and 73. My cluster is screwed anyways from opening it up too much lol. Im looking for a fresh one.
Old 09-28-10, 05:52 PM
stockhatch
stockhatch's Avatar
OIC. One day I may get one too. My needles are burnt and I have an auto cluster. Good luck man. I'm going to try to get mine working this weekend.
Quick Reply: Tach adapter or resistor mod for a 2jzgte?
