help with auto tt wiring
Oh, and IK1 pin 22 is related to the OD circuit. I dont know the full functionality of that circuit, so I cant say whether putting the car in L should energize it or not. I would start by verifying all the pins and colors between the gear indicator and IK1 are correct.
I am referencing Supra and Lexus wiring to verify colors vs pinouts, so bear with me and I will try to get you a full breakdown on the IK1 pins.
pin 14 is dark green with gray marks. pin 16 is lime green with yellow. Weird thing is that pin 14 get the 12v when in D but its connected to pin 9 on ecu plug. Didnt you tell me that 2 is suppose to be connected to that? By the way the two pins were reversed before i made the correction.
this is the only diagram ive been able to find of the nsw
http://personal.utulsa.edu/~nathan-b...23parkneut.pdf
When i put the gear selector on 2 i get no voltage from pin 16. Pin 14 has 12v when its in D but its spliced into pin 9 of the e10 connector. Pin 9 is 2 not D.
Ok so i spliced the wire from pin 9 to pin 16 on ik1 and indicator light works fine now only thing is 2 doesnt light up because its not getting 12v when i put it in 2. Im not worried about that i just want it to drive right. Ima take it for a spin and report back.
Mines was the same that how i burnt it. Cant wait for the one aligas sending me. I also have some ls400 calipers on the way, my damn boost problem is killing me though. If i go wot right away it will only boost 3-5 psi, but if i let it build boost i can boost 15psi no prob. Ive been working on this for a while without any results.
Thats what im going to do tomorrow. Ive replaced so many crap on it to try to get it to work. If i only had the money to go single lol. So you had to tap the ingnitor wire to get your tach to work?
Well, I tapped the igniter wire and it still wouldn't work. I was pissed! I eventually figured out that I had accidentally fed the tach out pin of the igniter with 12v
My mistake! Anyhow, once I cut the voltage to that pin on the igniter, the tach started working. Long story short, mine was a self inflicted wiring issue. Yours may just work if you tap the igniter wire. Its the small black wire on pin 1 of the 4 pin igniter plug.
