swapping companion flange for the getrag v160 and gs400 diff
My mechanic was in the process of dropping in my v160 when he ran into a snag today. He said I'm gonna need to buy another companion flange from an sc300 diff so he can swap it over. Can he just remove my old companion flange from my old driveshaft? I have a gs400 rear diff and custom driveshaft made to fit the v160 and gs400 diff.
If the DS is make for V160 and GS400 end,and you are not using the GS rear end you can just swap the flange from the Your stock Diff to GS4 rear flange.
My question are:
What Diff do you have?
Was the DS made for V160 and GS4 rear end?
My question are:
I am using a gs400 rear end and a custom driveshaft made to fit the v160 and gs400 rear end. After doing some searching, the rear flange bolt is 35mm right? I'm gonna have my mechanic swap out my stock companion flange from the sc pumpkin over to the gs pumpkin.
Unless you swapped the GS4 flange with SCXXX one before the V160 swap and you were using the GS4 rear with SC flange in that case yes you will need to buy the GS400 flange from lexus.
Because the GS diff will not bolt up to the SC Drive shaft unless you swap the flange.
sorry to bring this one back
ive ran into a similar problem
im swapping a auto tt diff into my sc and the companion flange thats on the auto tt diff wouldnt align properly so i was going to take the one off my sc diff and swap over to the auto tt dif was wondering if anyone knows how much to torque it too as i dont want to mess anything up
See this thread. There is a right and wrong way to do this. Any good mechanic will know the right way.
https://www.clublexus.com/forums/per...supra-lsd.html
PR FIEBRU
07-13-11 03:03 PM
JeffTsai
North Texas Lexus Club
05-13-11 08:58 AM
JeffTsai
03-16-08 12:34 PM
