turbo on na 2jz-ge
turbo on na 2jz-ge
will a stock 2jz-ge hold boost? what needs to be done for it to hold at least 14 lbs? sorry im new to the 2j just traded my celica gt for the sc today and im loving it
everyone is going to tell you to search..just an fyi..and you really should theres SOO much info out there..
anyway..you can do two different ways..safely-thicker hg and bigger injectors ought to do it..
or you could just upgrade injectors and get a good ems + tuning..
on top of all that..14psi doesn't mean much honestly..turbo size matters when it comes to psi..what are your actual power goals??
are you auto or manual..auto wont hold but 300-350whp
and like said search theres a lot of info ..also check out clubna-t a lot of info there as well.
Ill be nice and give you a link and a small piece of info...
SEARCH!!! Has been covered thousands of times. I understand your new, but there is a search function up top that will answer ALL your questions and then some.
And for the link: http://forum.clubna-t.com/ <<<IMPO, one of the best resources for na-t info.
To answer your question in short to prevent sounding like a total as*, yes your na 2J can handle boost, safely up to 9psi safely on stock compression and fuel using an SAFC2/Neo and will make approx. 310-330rwhp.
