A/C Questions and Answers
Old 08-08-02, 09:09 PM
pcmw
pcmw's Avatar
I think that was a very good assessment of the ordeal Kathleen...
You got the best deal on the repair because you now have the 'piece of mind' part of the equation.
Congrats on good research.
MW
Old 08-08-02, 09:50 PM
kathleenkmh
kathleenkmh's Avatar
Thanks! I'm learning...
Old 07-31-03, 01:02 PM
EmeraldLexuSC3
EmeraldLexuSC3's Avatar
Post A/C indicator light flashing on SC
Does anyone now why the A/C indicator light will be flashing?
(My first thought would be some sort of a service indication.)
Old 07-31-03, 01:12 PM
ACleanSC4
ACleanSC4's Avatar
I just recently had my light flashing also. I had it checked up and my A/C compressor was locked up. I had to replace my compressor and drier. Not a cheap job to do, new parts & labor would be $800+
I bought a rebuilt one and had it installed for about $400
Good Luck!
Old 07-31-03, 02:02 PM
EmeraldLexuSC3
Post
Wouldn't the compreesor make noises if it's going out?
I am hoping the A/C just needs a re-charge service
Old 07-31-03, 03:11 PM
ACleanSC4
ACleanSC4's Avatar
That could be it also. A recharge would probably do it for you. I didn't hear any noises at all when my compressor went out. It was used for 11 years without proper maintenence. I was told when I changed it that you should have it checked every year if you use your A/C regularly to have it flushed/lubed.
Old 07-31-03, 03:48 PM
hwallen172
hwallen172's Avatar
There was a thread here recently about AC diagnostic codes. I found it by searching for "diagnostic codes." Here's how you get the codes:
Running the A/C system diagnostics: When switching ignition ON push RECIRCULATION and AUTO buttons together and watch the LCD aircond. system screen normally used for temperature settings for a numerical code indicating the problem area. BTW, zero zero (00) means normal. First, all indicator lights will flash 4 times, then a buzzer beeps. When error codes are displayed a short while later, slower display (step mode by repeatedly pushing Fresh) can be activated by pushing FRESH. Hitting OFF stops the diagnostics.
There is a list of the codes in that thread that I would paste into this reply, but they're in a jpeg and I'm far too lazy to figure out how to do that.
Old 07-31-03, 04:21 PM
EmeraldLexuSC3
Post
Thanks hwallen172,
I found the thread you mention, after further research..
https://www.clublexus.com/forums/sho...agnostic+codes
I'm hoping it's low on freon!
Old 07-31-03, 06:53 PM
EmeraldLexuSC3
Unhappy
I have not done the AC diagnostic yet, but driving home from work, I noticed that the compressor
is starting to squeal and making unusual noises. So for sure, I know that the compressor is going out!
Damn, what better timing than during the freakin hot months of California! 20+ continuious days of triple degee digits!
Old 07-31-03, 09:42 PM
siniquezu
siniquezu's Avatar
Talking
Get your refrigerant changed too.
Old 07-31-03, 09:43 PM
siniquezu
siniquezu's Avatar
At least you don't need to change your expansion valve $_$
Old 08-01-03, 09:18 AM
messysc
messysc's Avatar
When the A/C light is blinking it means that the compressor has failed.
Old 08-01-03, 09:51 AM
EmeraldLexuSC3
Post
Thanks all for your input!
And yes siniquezu, I plan on chaning out the freon!!
Old 08-01-03, 11:48 AM
sweetsc400
sweetsc400's Avatar
My ac light was flashing the other day. I just turned it off and then turned it back on and everything was ok. It's as quiet as can be. But after reading this I think I'd better have it checked out. I'm going to try the code checking thingy first. Thanks for the info.
Old 08-01-03, 02:57 PM
ChrisSC300
ChrisSC300's Avatar
mine did it last summer. It started blinking then would go away for awile then came back. turned out the compressor was shot. not a cheap fix. was around 900 installed, the dealership tried to charge me 1700
Quick Reply: A/C Questions and Answers
