How Much for a 1JZ Setup?
Old 10-26-10, 02:17 PM
Exthultu
Exthultu's Avatar
Default How Much for a 1JZ Setup?
So guys, how much do you think a 1JZ-GTE with transmission and everything to do a swap is worth?
Old 10-26-10, 02:22 PM
ClearP
ClearP's Avatar
I'm pretty sure this topic has been covered. Are you looking for a 5-speed ones or auto? 5 speed will cost you more obviously, auto is around 1000-1500 depending on where you buy, Jhot is good I heard, but if you plan on taking the opportunity to replace all the gaskets, seals, waterpump, timing belt, etc.. you can potentially buy a cheaper one and spend money on replacement parts, of course then the cost will add up but will be good for you in the long run.
Old 10-26-10, 02:24 PM
BenStoked
BenStoked's Avatar
are you buying or selling? auto or manual? stock or upgraded/converted?
Old 10-26-10, 02:44 PM
stockhatch
stockhatch's Avatar
Swaps are getting really hard to find that are complete and in decent shape. I would say a nice, complete 1jz/r154 SOARER swap will go for around 2k-2500 these days if not more. Good luck finding one though. All I have seen lately are Chaser and Supra swaps.
Old 10-26-10, 04:36 PM
Exthultu
Exthultu's Avatar
That's the thing, a friend of my dads has a MKIII and its in good condition. I still don't know if it is manual or not. Just needed a heads up into what I should pay for it.
Old 10-26-10, 06:44 PM
stockhatch
stockhatch's Avatar
2000 tops if its a manual and in good condition IMO. The wiring will be more of a PITA, and the trans will need a new shifter to be right. I would offer around $1500 and go from there.
Old 10-26-10, 08:24 PM
Exthultu
Exthultu's Avatar
Its a whole MKIII Supra, I am going to get everything out of it for the swap. I am going to check it out tomorrow.
Old 10-26-10, 09:53 PM
1FastSc
1FastSc's Avatar
what about for an sc300?
Old 10-27-10, 11:27 AM
RED95sc
RED95sc's Avatar
my swap cost me $1200, and the guy threw in a 3" downpipe to fit the twins. i extended my harness myself (PITA), but that should cost about $150-$300 to get it extended. if you want the manual, add another $800. so a str8 drop in auto swap should not go over $1500, then like clearp stated, if you wanna do WP, TB, all gaskets, etc, then the price goes up
Old 10-27-10, 07:18 PM
1FastSc
1FastSc's Avatar
stock tranny works with the 1jz?
Old 10-27-10, 07:32 PM
StiCk3
StiCk3's Avatar
look to pay $1000-2000 for a motorset. Keep in mind you need a bunch of other bits like a new clutch, gasket set, wiring, extra dough for bad parts....it's much more expensive than i thought until i dove into it and im still not done with my car....
Old 10-28-10, 05:04 AM
stockhatch
stockhatch's Avatar
Exactly. Unless you plan to just toss the motor in with zero maintenance done, you will spend a minimum of $500 extra on maintenance and repair items. I spent almost as much on maintenance items, replacement parts, clutch, etc as I did on the engine itself.
BigWaveSC
04-16-13 02:23 PM
NozGT
SC- 1st Gen (1992-2000)
04-19-10 06:10 PM
otodemicks
09-13-08 12:37 AM
na4now
14
04-28-08 05:01 PM
Refujiado
08-23-07 08:58 PM
Quick Reply: How Much for a 1JZ Setup?
