na-t fuel injectors..who is running stock?
im just curious as to how many people on here are running stock injector and fuel pumps on there na-t kits? im thinking about getting a kit just curious if im only pushing 7-10 psi would this be a necessary to do???
i dont have na-t yet..however i plan to use stock injectors/pump and from all the research ive done they should have no issues around 300-330whp
of course you will need something to add more fuel on the ems/piggy back side of things but they are efficient enough for low boost.
i ran 11 psi with stock inj and a walboro pump briefly, safc maxed out to +50 in boost.
I turned it down to 9 psi later, I think anything more than that they will not be as reliable/consistent for every pull, but it can be pushed a few more psi as you can see.
I put down around 320 at 9 lbs but that was with the standalone, with the safc it def felt a bit slower.
