Occasional starter kickback
Old 10-29-10, 05:10 AM
stockhatch
stockhatch's Avatar
Default Occasional starter kickback
Sometimes when I start my car, it will crank over a couple revolutions and then act like it wants to kick back for a second before it starts. It almost acts like a SBC with too much advance... Anybody have any ideas on this? Is it possible to set base timing on these cars? I didn't figure it was something you could really adjust...
Old 10-29-10, 08:12 AM
good2go
good2go's Avatar
Absolutely. timing light, loosen distributor . . . etc.
Old 10-29-10, 08:43 AM
Ali SC3
Ali SC3's Avatar
he has a gte, there is no distributor but I would recommend checking your base timing at the least. It used to happen on mine when my cranking advance was set to high. I don't think you can change that though.
Old 10-29-10, 08:53 AM
stockhatch
stockhatch's Avatar
Hmm. Where would I clamp the pickup to check base timing on it? Over the #1 negative coil wire?
Old 10-29-10, 09:01 AM
good2go
good2go's Avatar
Originally Posted by Ali SC3
he has a gte, ...
oops. sorry, didn't see that
Old 10-29-10, 09:30 AM
stockhatch
stockhatch's Avatar
Ok, I found the timing process in the FSM, so I will look into that. It only does it every now and then, so I also plan to test my crank and cam sensors. Maybe one is going flakey and confusing it?
Old 11-24-10, 12:56 PM
stockhatch
stockhatch's Avatar
So I have been lazy and not really addressed this, but it seems to be happening more often lately. Also, I noticed a new behavior... Sometimes the car cranks longer than I would think necessary before firing up. This seems to happen more when its up to operating temp on hot starts. I really am starting to suspect either a cam or crank sensor now... When I get back from the Holiday break, I will test them all.
fastegg
16
08-25-16 09:12 AM
Neil4Speed
11-03-11 01:37 PM
KINGB
13
08-06-11 05:13 PM
Scott1258
05-15-11 02:41 PM
TheRonTom3
21
08-30-08 02:02 PM
Quick Reply: Occasional starter kickback
