radiator light comes on and off mid drive?
Guys my radiator light comes on intermitenly --has been since i bought the car almost a year ago---the fluid is full and always has been---what can be causing this?
Does the rad just need a flush or is this something else--thermostat or some other gadget?
Also Can worn brake pads cause the e-brake light to stay on?
My pads are quite thin and are do for a change but today i noticed the light on the dash for the e-brake is starting to come on and off mid drive-----im assuming it is due to the pads?
Thanks in advance guys
I don't think i've seen the radiator light before. Is it for that or for the windshield wiper reservoir saying the level is low?
As far as the e-brake. There is no sensor for the pads. The sensor would be for the brake master cylinder fluid level. As your pads get worn out, the fluid level goes down. Also an indication that it is about time to replace the pads. If you just plain don't want to see the light then just add more brake fluid. I'd change the pads tho.
no the light ussually comes on when i first start the car and it is warming up ---once i get driving it ussually goes away-----it goes away sometimes for weeks or months on end --im not sure what it means exactly
yes my pads definitely need to be swapped out ---------but in the meantime ill just top up my fluid ----thanks guys much appreciated----i realize these are not serious matters
and in terms of filling up the fluid------can any dot 3 fluid work ? or is dot 3 for power steering i forget.
MattLS400
28
02-21-14 04:25 PM
