1jz swap, dropping fuel guage needle?
Mine's a 93, I don't think anything changed between 95 and 93 other than the newer front bumper and tail lights. Mechanically and electronically it was all the same, except the fog lights. So I don't know what would cause the difference in the fuel gauge reading.
Is it a big deal to you that people think your car is empty if they look inside while it's off? haha
I tried swapping the actual fuel level sensor in the tank last night and it still dropped after turning the car off.
Since i first started this post i also have swapped to an aristo harness and jdm 2jzgte ecu
while i was doing the swap the cluster went to lextech for a stock rebuild.
I also had to do the resistor bypass mod to get the tach working (im suspicious this may have something to do with it)
im curious if other 1jz swaps with 95-96 clusters have this issue
alwaleed
IS - 1st Gen (2001-2005)
01-27-19 10:03 AM
SupraDremr
Performance & Maintenance
03-14-13 07:10 PM
schef300
SC- 1st Gen (1992-2000)
06-11-10 07:16 PM
