Head Stud question
Head Stud question
So Ive been driving the GTE for about 3 months now and I want to go ahead and re check the torque on the Arp's. My question can I just remove the valve cover and slip a socket down in there. I ask because when I removed the head (OEM) i HAD to remove the cams to get the studs out. Its getting cold really don't feel like disassembling and doing timing over
^ haha if I turn the boost up anymore im gunna rip this tranny apart and be out of a car lol 14lbs is enough for now. Ya I still have a little smoke when I sit at a light for a while or when I first start the car up, my guess is valve seals so I might do those. So for another question if I remove the head to do that and install will I need another re-torque of the head haha?
I pulled the head of the my block last week and i tell you , i can break those nuts loose without alot of tq.
I originally torq them down to 90lbs but but i was taking them off i didn't not feel like 90lbs seriously.
There is a thread on SF about the whole retorq thing , and i was going to do mine but end parting out the car.
Next time i build another engine i will use the Stock headbolts...
If you do the valve seals, I highly recommend the toyotools VSS tool. It is kinda expensive, but REALLY made the job a piece of cake.
The only thing you may need to do is drill a small hole in the handle of it. The machining on it is so precise, when you go to flip the tool insert over, it will form a suction and can be a PITA.
Like 10 seconds to drill a small hole, and it allows the suction/pressure to bleed off so the tool is easy to flip.
http://www.toyotool.com/VMT6%20Buy.htm
