Proper W58 for the sc400 Swap
Old 01-27-11, 09:04 AM
Ali SC3
Ali SC3's Avatar
Originally Posted by squrilbait
i got my trans from a 91 supra with the extended housing its susposed to be the same as the first years of the sc300 if it doesnt fit the way i want it to its getting a hack and slash job on the shifter so it will fit i will let you guys know how it goes.
you just went the hard way to keep an older w58, and all that work is not worth the difference in price. good luck.
Old 08-01-12, 06:18 PM
azriel
azriel's Avatar
I'm going to be using a w58 out of an 88 supra in my sc400 with a 2jz->w58 bell housing.
I'm fine with having to make a trans mount, I'm also ok with modding the stock shifter. my question is, will the stock auto driveshaft fit?
Old 08-01-12, 08:48 PM
BenStoked
BenStoked's Avatar
nope. a340 and r154 are totally different output shafts.
Old 08-01-12, 09:05 PM
ihiryu
ihiryu's Avatar
You'll need the shifter from a 92-94 300.
I used the 300 drive shaft also.
Even with the 300 shifter it still sat too far forward.
Old 08-01-12, 09:11 PM
azriel
azriel's Avatar
I'm not using an r154, its a w58 out of a mk3 supra, lol. But after some investigation, the a341e doesnt even have splines. so I guess what i need to know is, can i install a w58 yoke onto the stock sc400 driveshaft?
Modding the shifter is easy I'll just weld a peice of steel in the middle to pull it back 3 inches. I'm only wondering about the driveshaft really. It's funny that nobody mentioned needing to change the drive shaft. not even in the list thread.
Old 11-22-13, 03:47 PM
cali108
cali108's Avatar
Default will
will this trans work?
I believe its a JDM w58
for my 92 sc4 auto to manual swap
Old 01-21-14, 04:30 AM
SlowC400
SlowC400's Avatar
1UZ>|[quantum kit]|w58.
Old 01-21-14, 12:40 PM
hmhatch
hmhatch's Avatar
It's not supposed to be the same and it isn't the same. You bought the wrong trans. Why not just buy the correct parts the first time instead of going the cheap route and butchering it all up??
Old 01-21-14, 02:56 PM
Ali SC3
Ali SC3's Avatar
has already been stated many times, people have done it with the older ones there are lots of ways to do shifters, but if you want it as close as possible the newer w58's will simplify that part.
Old 03-13-14, 09:57 PM
kolessc400
kolessc400's Avatar
Im getting the shifter housing extended for sc400 the w58 is out of a 92 sc300.... there is a guy on ebay that is doing the extensions for the r154s and w58... he does them for $225 im doing a whole thread on this swap with the older w58 there is 2 options extend the housing and the shifter seat, or extend the shifter... the housing and seat are ideal....this is the guy on ebay
http://www.ebay.com/itm/R154-shifter-extension-/131126041009?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e87b899b1&vxp=mtr
Old 03-14-14, 09:47 AM
Ali SC3
Ali SC3's Avatar
I think you missed something, when we mean older w58 in this case we are talking about w58's from a mk3 supra that the shifter is too short. the 92sc300 w58 will fit the 400 you just have to use the 92 shifter, the housing is already extended a little vs a mk3 w58.
So any of them from an SC300 will fit pretty well, 92-94 w58's you will still have to drill a hole in the trans tunnel if you were auto (all sc400's are), and if you have a 95-97 w58 then you may be able to reuse the auto hole since these use a remote shifter design and a straight shifter, but the shifter cage may contact the auto tunnel if so you may have to mod it or get a supra TT or 95+sc300 tunnel and swap that in. The supra one is less expensive believe it or not.
If you have a older mk3 trans as in pre 92, then you have to extend the shifter and then do above like you would for the 92-94. It is also debated that the newer w58's have better synchros, but I am not sure if that is confirmed or not.
Old 03-14-14, 11:02 AM
KahnBB6
KahnBB6's Avatar
Received 1,250 Likes on 870 Posts
I can state that one major difference about the older MKIII W58's and the SC/MKIV W58's is in the use of an aluminum sandwich plate in the former and a steel sandwich plate in the latter (which makes it a bit stronger). Synchros being improved I can't say.
Old 03-14-14, 02:56 PM
Ali SC3
Ali SC3's Avatar
*Edit* removed my info I think Khan is right on the switch to steel plates.
Its actually in the wiki
http://en.wikipedia.org/wiki/Toyota_W_transmission
Old 03-14-14, 09:37 PM
kolessc400
kolessc400's Avatar
So I do not need to extend the sc300 92 non tripod style w58' shifter housing I heard it was shorter by 2 and 3/4 in.
Old 03-15-14, 10:26 AM
Ali SC3
Ali SC3's Avatar
If its from an SC you should be fine as long as you have the right shifter, that 92 SC300 trans should have a bent shifter that makes up the rest of the difference, putting the top of the shifter it in the middle of the console.
my understanding is the mk3 w58 comes up shorter because it has a shorter housing even though it also has a bent shifter.
mk3 on the left, mk2 on the right
from here
http://lextreme.com/forums/showthrea...t=14743&page=9
see sc300 trans housing is a little longer, but not by a whole lot.
Quick Reply: Proper W58 for the sc400 Swap
