does the sc400 tranny only take 2 quarts?
Old 11-16-10, 05:42 PM
chnk
chnk's Avatar
Default does the sc400 tranny only take 2 quarts?
I've been needing to change my transmission fluid 40k miles ago, and well i go to autozone and the it only takes 2 quarts of fluid? I bought only 2 quarts of castro high mileage transmission fluid.
also this is my first transmission fluid/filter change ever so ill probably be back with more questions
Old 11-16-10, 06:36 PM
Subjug4tor
Subjug4tor's Avatar
The transmission holds much more than that, its just that draining it and dropping the pan, you only loose 2 quarts, the rest is still in other parts of the trans. If you need to change all your fluid, you can either go get it flushed somewhere, or do a drain and refill, drive it a few days, repeat that a few more times, then finally drain, change the filter, and refill the last time.
Old 11-16-10, 06:40 PM
chnk
chnk's Avatar
should i just drain it? i havent touch the tranny in 40k miles
Old 11-16-10, 07:05 PM
imDementeD
imDementeD's Avatar
yea i think in the sc manual it states the tranny holds 9qts of oil total.
Old 11-16-10, 07:45 PM
Subjug4tor
Subjug4tor's Avatar
Unless your trans fluid is brown/black/smells like burnt fluid, You should be find with just a drain a refill one time. Change the filter if you want, but if your fluid is good and clean your filter probably is too. Our filters aren't much more than a metal screen from what I know....
Also, as I'm sure someone will point out soon enough, you really should only use Toyota type T-IV trans fluid in the sc400 tranny. Lots of people have reported slipping/ shift problems/etc. after doing a fluid change with any other kind of fluid. Even if the bottle says its compatible with T-IV fluid, I would go to Toyota and buy a few bottles just to be safe.
Old 11-16-10, 08:04 PM
chnk
chnk's Avatar
thanks for pointing that out, ill stop by toyota tomorrow
Old 11-16-10, 08:06 PM
94LEXUS400
94LEXUS400's Avatar
yeah, I just did drain and refill like 3 times today..cost me 60 dollars in fluids...so 6 quarts total but I drove it on highway between changes..
I used Toyota T-IV fluids...I think its a cheap insurance for you to go and drain and refill like me with Toyota T-IV and replace all the fluids since you have "wrong" type of fluid in there...go with toyota genuine T-IV unless you want to go with amsoil..
Apparently amsoil is ok cuz my friend flushed his tranny with amsoil and its running strong.
Steve
bkos90
03-03-15 02:03 AM
Kalogerus
04-09-12 12:49 AM
JRabs
04-02-11 03:52 PM
margarita
32
04-10-09 07:06 AM
carguy07
RX - 1st Gen (1999-2003)
12
01-11-08 08:40 PM
Quick Reply: does the sc400 tranny only take 2 quarts?
