SC400 Knock Sensor Voltage Range
They make a voltage signal when KNOCK is present. What problem are you having? (Why do you ask about the knock voltage?)
Here is a quick video.
http://www.youtube.com/watch?v=0xI94ZDF54Y
http://www.youtube.com/watch?v=L8xRJ...eature=related
No, I just want to know the voltage ranges of the knock sensors. I.E. for what minimum voltage wave amplitude being put out by the sensor does the ecu think that the knock sensor is working properly (It has to see something other than zero I am pretty sure); and what amplitude range does it assume low knock, medium knock and high knock. I know how they work. I just can't find any values for these.
