1jz single low boost dyno results!!
Old 11-22-10, 01:48 PM
okula247
okula247's Avatar
Default 1jz single low boost dyno results!!
bone stock 1jzgte
stock Ecu
stock Cams
stock injectors
255 walbro fuel pump
fmic 2.5 hot 3in cold
gt4082 t4 turbo .81 exaust side
tubular top mount
13psi car was rich as hell so more power could be made But. 319whp 305 torque
supra 550's, adfpr,bcc,afc will be installed in a couple months.....then will see what 20psi will do!!!
Old 11-22-10, 03:49 PM
Mr.1.5
Mr.1.5's Avatar
Those numbers seem a little low. Should be a lot better when you lean the car out.
Old 11-22-10, 04:15 PM
Slow_Sc3
Slow_Sc3's Avatar
dude you need a TUNE! 1jz run rich as hell stock adding more boost is just going to compensate for more fuel..... get your safc/ 550s installed and go back!
Old 11-22-10, 04:39 PM
good2go
good2go's Avatar
Agreed, definitely focus on a better tune
Old 11-22-10, 06:41 PM
94_soarer
94_soarer's Avatar
Indeed!!!!
im on stock twins with a bcc,scc,3" dp,4" fimc, 3" full exhaust with stock injectors and the car is jus begging for a more fuel...
Old 11-22-10, 07:08 PM
okula247
okula247's Avatar
thanks for the feedback.....i was looking for more like 350whp but like you guys and i said....car is running pig rich... This was just a baseline dyno just to see where i stand. I already have 550's. But the rest i dont have.....and money is tight...so its a slow go!! It might just get it all done at tax return time.....maybe even some 264's(cams) More too come for sure!!!
stockhatch
11-06-13 07:44 PM
antonio356
12-12-11 01:33 PM
StuntKing
03-09-11 10:10 PM
kaosman
27
03-09-06 03:13 PM
chidoks
15
11-17-05 09:07 PM
Quick Reply: 1jz single low boost dyno results!!
