E85 fuel setups chime in
Old 08-05-11, 10:28 PM
SC51
SC51's Avatar
93twintrbo I run Two Supra Denso pumps @28psi base + FIC 2150cc injectors. 10an feed and 6an return. So far so good. I am running a 76gts@34psi on E-85 every day.
Lawrence
My buddy's running the same setup in his 9sec Supra. Two Supra Pumps (255s) and also I believe Kenne Bell Boost-A-Pump that when under full load it bumps fuel pump from 12-14v wot to 16-20v. Makes each pump flow 50% more
Old 08-06-11, 05:17 AM
99SC42
99SC42's Avatar
Kool i see a couple supra guys run that setup, i want something simple that will work great with my setup. I was going to do a surge tank but its alot of work i am trying to be ready in a week.
I finally made up my mind on how to run the pumps and i post the pics once i start.
Old 12-26-11, 04:03 AM
dejacky
dejacky's Avatar
How about some pics of your fuel systems showing how you fellas routed it under the fuel tank where the original banjo bolts were fellas?
menty
06-12-21 05:01 PM
mlo1956
NX - 1st Gen (2015-2021)
07-02-17 01:28 PM
Kevlar@BFC
Florida Lexus Club
05-12-09 06:06 AM
RedPhoenix
04-21-07 04:59 PM
Quick Reply: E85 fuel setups chime in
