Oil Warning Light
My oil light came on after I would go fast, and I was due for an oil change, so I got one. After the change, later that night I raced someone (won) and the light came back on. Is there anything wrong with my car, or do ya'll have any suggestions? Thanks!
-Richard
-Richard
is it just the yellow light?
the red oil light is the one you have to worry about the yellow is just a low oil light and your sensor could just be going bad (did you check your oil just in case?).. every once in a while mine does the same thing your talking about... eventually I figure I will have to replace the sensor.
Originally posted by bizzy928
Actually I don't think that our sc's have oil "level" lights, they are oil "pressure" lights.
Check your oil pump. When those lights come on, its pretty dangerous.
dont scare people Bizzy!
....but until I read this thread, I didn't know there was a yellow and a red light. I thought there was just one light, for oil pressure.
In the 5 years I've had my car, I've seen the light come on several times. Once, it came on while I was just idling at a traffic light. It sure scared me, but now I know it will flicker from time to time, and as long as it does not stay on, it is probably just the sensor having a bad day.
i am bring this post back from the dead.i did a search like everyone always says to do.ok now i have a 98 sc300 w/ 70k miles.when i start my car after it sits for a while the oil pressure light blinks for about 2-3 secs when i start it up.is this a problem?it does not blink while i am driving the car. it is the indicator all the way to the right and it is red.i do not know if this has been happening for a while because i just noticed it.
thank you for all your help
If the light it still blinking with oil full, get sensor replaced.
~Alan
Originally posted by SPORTcoupe
Fill up your oil until you're at the top notch on the dipstick(if you don't know the proper technique for checking oil level, check the car's user's manual)
~Alan
~Alan
Heres a good time to get this out
THE SC300's OIL CAPACITY IS 5 QUARTS, NOT 4 LIKE THE MANUAL SAYS
Trust me, I am very pissed at Lexus for having my owners manual say my capacity is 4.1 quarts, when in actually it is a full 5 quarts. I may have done some damage by having my oil down a quart shortly after oil changes, and I blame Lexus for this.
Mine says 5.1..... 4?! are you sure?
I was talking to a Lexus certified tech that puts in 6 because you never get a full quart out of a quart of oil.
hope thats your problem.
and for all the people that dont know how much oil to put in, FILL IT TILL THE OIL CHECK STICK SAYS ITS FULL. no more no less. and make sure to start it and shut it off before you check it to make sure the oil went into the filter.
