How to: Trunk Lift Support w/ pics...
#76
Originally Posted by kaotiq
I gotta do it guys... sorry. Kicking up an old thread. Here is my problem
I followed the instructions perfectly as said here. For some freaking reason, that first step of trying to get the nut off just won't go for me. That damn nut just won't budge. I have almost damn hear stripped the nut. I tried WD-40, liquid wrench, but nothing. No progress.
I was thinking about dremeling the plastic connector that connects directly onto the pivot ball of the trunk support. Any thoughts on that before I go ahead and do so?
#78
Originally Posted by SC400Dude
Same thing happened dude...hard as heck to loosen...I gave up....next time(If I have time)...I'll try the air tools
so I take that as a "yes" to my question
#81
Originally Posted by PERRYinLA
You may have followed the instructions perfectly, but you missed posts #10 and #59.
#82
You said you "tried WD-40, liquid wrench..", but you never mentioned heat, hence my comment.
The bolt is hard to remove because they use Loc-Tite at the factory, and once you apply enough heat to soften the Loc-Tite, it should be as easy to remove as any conventional bolt. How much heat to apply is a judgement call (but for you beginners, you can stop once things start glowing).
#83
Hit up the Home Depot and get some Liquid Wrench. A little bit of that plus a little heat should do the trick..
edit: just read the previous post, I couldn't get the bolt on my passenger side off as easily as my driver's side, but the COMBO of Liquid Wrench followed immediately by heat did the trick, where Liquid Wrench alone did not.
#84
...I followed the instructions perfectly as said here. For some freaking reason, that first step of trying to get the nut off just won't go for me... I tried WD-40, liquid wrench, but nothing. No progress.
I am assuming that everyone is still against the idea of dremel the ball socket of the trunk shock? My new shocks didn't come with a new ball joint attached.
#86
whew, finished. i got the ac delco ones and the install was cake. pointers, the ball joint is a really easy clip in, so, just thread in the bolts first, then snap in the strut. i have no idea if thats been mentioned, but my arms are too tired to skim through all these pages, lol. its not the stock 12 mm, its a 7/16 wrench now. just an FYI. and mine DOES pop opened. i have a wingless trunk with an added stock 93 wing, and i used "with wing" struts. i turn the key, and the thing pops opened, and lifts all the way up, its sweet, lol.
#87
So you actually used a 7/16 instead of a 12mm?
#88
#90
rock auto discount code??
anyone got the latest rockauto discount code?? i guess im a little too late for the latest one?? probably aint much of a discount, but every little bit counts..
