2jz-ge turbo header wont fit big turbo fix
#34
yes, i have the jig for it. but i dont have any premade cause of lack of interst ( i presume because of the shorter distributor cap, you can use it for up to i believe a 61 mm or so turbo and/or the fact that you can just cut the flange off the header and turn it, but doing this will somewhat restrict the flow to the turbo which is y i decided to make the flange in the first place and not just cut and turn mine) they end up costing 65 bux plus flat rate shipping. its made for a front facing intake manifold it MAY fit w/ the na intake manifold but i have not tried it yet, if the short distributor cap wont work for you and you have a na intake manifold and are still intersted in one of these spacers i can throw my na intake back on my motor(its still apart right now and it would be easy) and check it/ take some pics for you. let me know ether way please
#35
I'll let you know what I decide to do. What I'd love to do is be able to fit a borg warner or gt42 / 7175 billet sized turbo charger on the ebay manifold (if it's even physically possible). I figure this spacer might give enough space from the #1 runner to clear the compressor housing.
#36
Cool, I can find T3 to T4 adapters for 40 bucks but T4 to T4 just doesn't exist.
thx for the t3 spacer pic!!
#38
There some some good pictures of the "clocked" t4 flange welded on top of the divided flange that comes on the turbo xs manifold. This was on a t61 and it allowed him to clear the distributor fine, plus it gives more pictures to reference to.
http://forum.clubna-t.com/showthread...odify+manifold
#39
Club Na-T has a ton of useful info:
DaveH's GT42 Spacer on ebay header???:
***The angle of the header t4 flange used here looks much different then the ebay ones**
http://forum.clubna-t.com/showthread...highlight=gt42
"This does not clear the distributor, and you will need a TT style intake manifold to run this setup." <--- LOL
I'm not so much interested in the GT42, but possibly the billet 7175 or a Borg Warner of equivalent size.
#40
More lurking around club na-t and found a member that was able to fit a borg warner s380 onto an xspower ebay manifold.
Fitment pix start at post #4:
http://www.supraforums.com/forum/sho...th400-s380-etc
I was pumped to finally find someone successfully mount a beast borg warner on the ebay manifold without some crazy $$$$ manifold. Just thought I'd share, most of you guys have probably seen that thread already but I figured I'd post it for reference.
