1993 sc300 108k acceleration sputter HELP
no check engine lights. replaced engine sounds good . when i drive at about 16 miles per hour or light acceleration the rpm shoots back down from 2 back to 1 then goes back and regains power after i step harder on gas...same at around 40 miles per hour a little sputter and car jerks.. car runs good just acceleration isnt smooth all the way through . hesitates and loses sum power especially when i sit in drive at a light for a while then try to accelerate that power loss comes right back
ANY IDEAS ? HELP ... REPLAY ASAP THANK YOU TO ANY REPLIES
Sounds like the same problem I was having. I got mine fixed, but probably not your problem. I was in an accident and had to replace every part connected to the left rear tire. The parts I got where from a 96 and mine was a 95. The traction control sensor connector is different. It plugs right in like it fits/works, but the inside prongs where different. I had to splice the old wire connector (got ripped in 2 in the acciedent) and reconnect it. Runs like new. So, I would say check to make sure your traction control is working properly. Try driving it with it on, then off and see if there is any difference. Good luck! I know this is very annoying.
hellajoe
GS - 1st Gen (1993-1997)
09-11-22 12:18 AM
40, accelerating, acceleration, acclerating, car, exceleration, issues, jerks, lexsus, lexus, mph, rich, sc300, sputter, sputtering, sputters
