drain battery .02 cents please
So my battery keeps draining on me. I used my "good" battery out of my ls400 that i drive everyday and it still drained that one. I know it is not a weak battery becasuse i never have problems with LS.
It will stay charged all day but nights it will totally die. When i go to jump it, it jumps right away which is weird it does not need a minute or two of charging to turn over the motor. The alternator cannot be bad because a jumping the car on a cold morning will run all day.
I am hoping someone has had a similar problem. Battery terminals have never been tight but that doesn't have too much to do with it.
Isn't it possible that it's just gotten really weak and isn't able to generate any more than just enough to run the engine, but no accessories . . . like your headlights at night ??
Sounds like one of the plates is going bad in the battery.....
in combination with the cold weather it will not keep a charge for more than 2-3 hours....
Time to replace the battery....getting a new alternator will help, but not resolve your problem....
if you want to know if your alternator is bad or not get the car started (jumped if needed) then remove the positive and neg terminals, and if the car runs then the alternator is good
He's tried 2 batteries so far, one of which was a "known-good-working" battery. What makes you think it's both batteries?
You really need to add a significant accessory load and run it at more than an idle to conclude that it's putting out enough amperage to run the car as well as charge the battery. And of course, you can always get any auto parts store to test your alternator for free if you pull it out.
agreed
Keeper of the light
Batteries cannot magically discharge, you have a gremlin.
put an ammeter on the battery and start pulling fuses until you see zero drain.
You can also be seeing an issue that I had with my alternator that is rare where the regulator is shorting out only at certain points of rotation and drains if it is shorting when shut off. You'll find the issue regardless of what it is, with a simply fuse test and the ammeter or dmm.
i put a fully charged battery in the car from my ls400 "daily driver" and the battery was drained in the morning. The doors were closed no electronics running, just the clock on the dash. The battery was dead in the morning, i am thinking that i have a "gremlin" something pulling amps from battery constantly.
I am not saying the alternator is good but obviously it is not the problem of an draining battery when the car is not running.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
the car is dying over time while sitting in the garage, not running. has nothing to do with alternator.
Keeper of the light
Well never say never, it COULD, but only if the regulator is shorting to ground and that is a rare occurrence. It happened to me last year. When you connected the + battery post it would arc just like going dead to ground and kill the battery. It's very very rare though.
In any case nobody but YOU can find the short and the only way to do it is with a DMM or ammeter and pulling fuses so have fun.
