Na-t with a 4 inch turbo inlet
There seems to be alot of problems with fitting a turbo with 4in inlet in a Na motor with the distributor cap getting in the way. im getting most of my parts together and while i had some free time i decided to modify my compressor housing to help it clear the cap a bit by downsizing to a 3.5in
cutting out the 4in
new 3in sleeve pressed in
another side by side to unmodified housing
hopefully this and slight clocking of the flange it should work out..? maybe? thoughts?
cutting out the 4in
it shouldn't cause any more restriction i just narrowed it in between the compressor map width enhancement grooves and the shroud as long as it can breath from the side still its fine.
im in Ventura
im in Ventura
Can't say I have seen it. I have a burgundy/dark purple with a vertex knock off on 19's. I haven't driven it for a while. Oh there is a second SC similar color to mine but it has the ebay want to be supra lights on the west end of town. I would like to check out your build some day.
