Quick NA-T Question
just a basic na-t setup i pieced together, the only thing is that i am running blow through setup with the maf sensor placed before the throttle body.
didn't have to tune for low map since i am on stock injectors and hg. turns on every time with no problems, idles real nice and drives like stock until i boost ( 10.1 stock compression and boost =
YeA 2jZ thanks fellas, bluerex what size turbo ur running ? And SC51 what size WG do you recomend ? 50mm ?
yea 2jz, its the xspower t61 turbo with a tial 44mm wastegate. the reason i picked the xspower was because i had planned to run lower boost for a long time with it until i switch to e85 then i will switch to a different turbo. oh and the seller was local with a good price.
thanks ali sc3, i plan to switch over to 7m cps over time..
